55 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> REVIT 2013 - Angled Layered Wall Ends
Tue, Dec 3, 2013 at 6:44:21 AM | REVIT 2013 - Angled Layered Wall Ends
Delo
Hi everyone,
I have to create some walls with angled ends. have no problem in that creating a void wall-hosted family that cuts the guy's end. the issue is: this wall has many layers and using this method, these layers don't wrap properly at this angled end. what can i do?
P.S. how can i choose which layers have to turn at the ends of the walls and which not? is there a way to do that?(in the image i would like only the last layer on the left to wrap the wall end)
Many Thanks
Tue, Dec 3, 2013 at 7:21:12 AM | REVIT 2013 - Angled Layered Wall Ends
Since this is just a 2D problem, use the edit cut profile tool.
Tue, Dec 3, 2013 at 8:06:41 AM | REVIT 2013 - Angled Layered Wall Ends
Delo
actually, it is not, because i need that wall to have that shape in 3d and to appear with the correct connections of the layers in plant when they turn at the angles of the end..
Tue, Dec 3, 2013 at 8:18:34 AM | REVIT 2013 - Angled Layered Wall Ends
Only the outer layer is visible in 3D!  The finished exterior limit is where you have defined it.
non orthogonal wall ends
Wed, Jul 18, 2007 at 12:51:58 PM
Foundation Wall with Brick shelf (Layered)
Fri, Jul 29, 2011 at 11:33:01 AM
DRAWING ANGLED WALLS
Wed, Feb 20, 2008 at 7:53:30 AM
Adjust Wall Ends
Wed, Jul 10, 2013 at 9:08:26 AM
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:08 PM
Page generation time: 2.3445
