92 Users Online (91 Members):
Forums >> Revit Building >> Technical Support >> PDF printing problems
![1 Stars: 1 Votes](/images/stars_1.gif) |
Hi All,
Anyone ever had a problem printing to PDF where parts of the print are blanked out (see attached). Have tried pdf995 and Cutepdf with the same result. PDF995 support had no idea how to fix it. I have removed and reloaded both programs.
Sorry should have mentioned I am using Revit Architecture 2013
Does it print correctly to your printer?
I have no problems with the printer, just the pdf and it is only on random pages in the set.
![3.5 Stars: 4 Votes](/images/stars_3.5.gif) |
the perspective view looks like it has a masking region following the roof line of the lower image. is that possible?
or a roof set to invisible lines but hidden line view maybe?
other than that, what sort of computer are you running and how many apps/programs are running at same time?
it seems quite odd, i'd never met before but have you ever tried bullzip pdf printer?
i'm using this soft for pdf printing, and for me, it's good.
This could be your system. Try printing to PDF from another system.
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
Adobe PDF problems |
Thu, Apr 11, 2019 at 7:24:12 AM
printing problems in Revit 2013, windows 10 |
Fri, Jul 3, 2020 at 3:08:01 AM
Printing Shadows in .pdf file - Revit 7.0 |
Wed, Dec 22, 2004 at 9:16:23 AM
Printing Shaded Elevations to PDF |
Wed, Oct 19, 2011 at 11:23:07 PM
Members: | 2017156 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
