51 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> HELP!!! Problems with Room Tag
2 Posts No Rating |
Hi all,
M trying to create a room tag whereby I can modify the visibility of the labels to what I need in certain instances. Have managed to do so to a certain degree however, the new tags that I have created shows a "?" sign even when the visibility property if turned off. Any idea how to fix this? I need this for an upcoming project submission.
Have attached the file with the problem
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
From what I can tell this tag works ok. I don't have the shared parameter file to follow it thru all the way but the visibility 'type' parameters seem to work and I get get rid of the '?'.
Click the tag after placement, go to the type properties and turn on and off what you want. See attached. . . worked for me.
There are overlapping parameters (visually) but that's by design I assume.
Edited on: Mon, Dec 2, 2013 at 1:16:44 PM
But every time clicking on the tag and then turning it off, is quite time consuming and irritating..?? can anyone suggest some of the other solution for this problem..??
sydney |
Maybe it would be better if these were type parameters.
Room tag not showing in only one room. |
Fri, Oct 1, 2021 at 11:04:59 AM
Editing a room tag |
Thu, Oct 12, 2017 at 3:17:41 PM
Room tag problems |
Sun, Aug 24, 2008 at 12:19:37 AM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
problems with room tags |
Thu, Feb 16, 2006 at 5:12:52 PM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
