52 Users Online (50 Members):
Forums >> Revit Building >> Tips & Tricks >> Get Rid of Decal Boarder
![5 Stars: 2 Votes](/images/stars_5.gif) |
If you have ever used an irregularly shaped decal by using the cutout option then you know what a pain the decal boarder can be. Here is how to make it all but disappear in 3D views.
Make a custom line pattern (I named mine Decal Boarder) with a dot and a larger space, I used ½”
Then use override graphics to change the decal boarder to this line pattern. Then set the scale of the 3D drawing to a really small scale, say 12” = 1’-0”. The border line turns into dots at the corners of the decal and 4 dots is way better than a whole line. If you adjust the line color through graphic override you can make it all but disappear.
Enjoy.
I just discovered this does not work in Perspective views. I guess you can't win them all.
Decal Boarder and material scaling |
Wed, Nov 27, 2013 at 1:37:16 PM
Decal rendering |
Sun, Nov 9, 2008 at 4:02:33 AM
Decal 2009 issue |
Sun, Nov 9, 2008 at 5:29:42 AM
Revit Architecture 2013 - Decal Tool not functioning |
Mon, Jan 13, 2014 at 10:18:31 PM
Decal Placement |
Wed, May 1, 2013 at 7:55:41 AM
Members: | 2022380 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
