Forums >> Revit Building >> Technical Support >> Underlay using construction template on 2012 version
9 Posts No Rating |
I have always used the default template version but decided to try and use the construction template for a project I have just started.
I layed out the main level walls first and went to draw the foundation plan as I usually do.
Using the default template I have always been able to use the underlay and see the floor above so that I could layout my support for the above floor below as needed.
Using the construction template , working in the level below, the floor above will not display when I select it as my underlay .
Is there a way to get the level above to display? Never had this problem using the default template.
hi
construction template can underlay and show any levels that the default template can.
construction templates should normally display walls.
kindly check your visibily graphics, phase filter, and other settings that makes your walls disappear.
** dont be mad, i dont have much... i am homeless |
43 Posts No Rating |
check properties...underlay, change it from none to your selected plan,
then change the underlay orientation from celing to plan....
hope it work
9 Posts No Rating |
thank u,
Your suggestion to check the phase filter worked.
the phase was the problem. had to set both views to the same phase.
apprecitate it.
Template Version |
Tue, Apr 22, 2014 at 2:02:59 PM
Construction template missing |
Mon, Mar 28, 2016 at 8:54:29 AM
Revit 2012 template family files (.rft) |
Tue, May 10, 2016 at 7:12:25 AM
Underlay as dashed lines 2012 |
Sun, Nov 24, 2013 at 9:26:03 PM
Revit 2009 Crashing In View Template Creation |
Tue, Oct 25, 2011 at 11:45:52 AM
Members: | 2100980 | Objects: | 23173 | Forum Posts: | 152292 | Job Listings: | 3 |
