115 Users Online (114 Members):
Forums >> Revit Systems >> Technical Support >> Visibilty Graphics Greyed Out
5 Posts No Rating |
I have linked a structural revit model into my model and want to turn some of the linked models layers off. When I go to visibilty Graphics, everything is greyed out with no options to select anything at all.
What is causing this????
Do you have a view template applied?
5 Posts No Rating |
Have never used view templates so not sure?
Fairly new user of revit
Take a look in your HELP file to learn a bit about them. My first guess would be you have one applied to your view, click on your view and under your properties see if there is one applied or if it is set to none.
5 Posts No Rating |
It is set to a view, does it need to be set to none?
Yes
5 Posts No Rating |
ok so that makes the VG box live again, but still not sure how to turn off Grid lines and levels off on the linked model.
Under VG>Revit Links> Display Settings> click on By Host View and in the RVT Link Displat Settings dialog box change from By host View to Custom and turn them off there.
You need to spend some time with your help file and check out some tutorials on linked models, worksets and view templates.
5 Posts No Rating |
Mant thanks for that.
Your right with regards to learning about worksets and view templates though. Been thrown in at the deep end on a live project you see and need to learn quick!
Been getting alot of help from youtube.
Wall Sweeps in Visibilty Graphics |
Wed, Jan 20, 2010 at 12:10:08 PM
Halftone setting in Visibilty Graphics |
Thu, Sep 29, 2011 at 9:48:08 AM
sweep visibilty |
Wed, Nov 18, 2009 at 12:51:27 PM
Half Revit model greyed out in 3d mode |
Wed, Jan 30, 2013 at 2:20:45 PM
plotting greyed out title blocks?? |
Fri, Jun 9, 2006 at 8:46:10 AM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
