49 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering not using full 100% CPU
Thu, Nov 21, 2013 at 10:55:27 AM | Rendering not using full 100% CPU
mneglia
Hello,
I am doing a rendering in Revit Architecture 2013 and I noticed that the total CPU usage while the rendering is in progress is only at 25% - 30%. Normally, when you render, the CPU usage it is at 100%. Also, the rendering seems to be taking significantly longer than it should. But really it just seems to be stuck on 13% and the time keeps going. The file renders fine on outher computers.
My system is:
Intel Core 2
Quad 2.66ghh
8BG of RAM
Nvidia Quadro 600
Windows 8.1
Please help!
Thank you!
Edited on: Thu, Nov 21, 2013 at 11:02:14 AM
Revit blog: www.bimeveryday.com
Thu, Jan 16, 2014 at 12:29:15 PM | Rendering not using full 100% CPU
mahlisuh
Are the other computers the same type of system?  I seem to remember hearing something about one windows program not being able to use more than a certain percentage of the CPU, or not being able to use more than one core if there are multiple.
New system, need CPU help
Thu, May 13, 2010 at 10:32:06 PM
Maximizing CPU in REVIT
Fri, Aug 15, 2008 at 3:39:39 PM
Rendering problem - Out of ideas!
Sat, Jul 13, 2013 at 11:47:50 AM
Rendering Crashes
Fri, Aug 6, 2010 at 12:50:23 PM
Vista 64-bit Memory Query
Fri, Mar 6, 2009 at 8:51:11 AM
Page generation time: 0.5516
