47 Users Online (46 Members):
Forums >> Revit Systems >> Technical Support >> Scale the model?
Can we scale the 3d model? The building is made of panels with different slopet, there isn't walls,windows,doors, etc. Can i make to be twice smaller or i need to do it all over again? Thanks
You can't scale a model. If components are controlled parametrically, then you can control with dimensions.
For instance, draw a box using 4 walls. Dimesion width and length. Click on a wall and change the appropriate colored dimension.
Export Revit to DWG - scale problem |
Thu, Jul 17, 2014 at 4:35:23 PM
11
changing scale |
Wed, Apr 22, 2009 at 7:01:31 AM
Large Scale Model Rendering |
Tue, Oct 24, 2006 at 6:12:05 AM
Scale bar on sheet onto to display at certain scale |
Wed, May 22, 2013 at 12:15:22 AM
scale image |
Fri, May 13, 2016 at 1:11:44 PM
Members: | 2069232 | Objects: | 23097 | Forum Posts: | 152259 | Job Listings: | 3 |
