86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit revit revit
Thu, Feb 16, 2006 at 4:05:41 PM | Revit revit revit
rusk43
When exporting revit drawings into autocad what is the command to remove overlapping lines?
Thu, Feb 16, 2006 at 4:47:02 PM | RE: Revit revit revit
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The command in AutoCAD is "overkill" but in your export settings-->options there is an option to do this during the export. Just simply tick the check mark.
Fri, Feb 17, 2006 at 4:17:00 PM | RE: Revit revit revit
Formfunction33
I wonder if "flatten" would work...it workes for objects(3d)...
**ATTENTION ALL REVIT GURUS** - Teaching Revit
Mon, Oct 6, 2008 at 9:30:42 PM
Revit 2009 : Coordination Between Revit Structure & Revit building
Fri, Jun 20, 2014 at 10:41:34 AM
Nested parametric use from Revit 6.1 to Revit 7
Tue, Nov 30, 2004 at 9:33:34 PM
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:39 AM
18
Page generation time: 14.1106
