36 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Curtain wall panel surface pattern
Tue, Nov 19, 2013 at 4:18:45 PM | Curtain wall panel surface pattern
RockFish
5 Stars: 2 Votes
I am trying to create a Kalwall system with using the curtain wall family.  All works out nicely with the exception that I cannot adjust the pattern location on my panels.  The curtain wall panels are created from a material that I have applied a 12”x24” surface patter (pattern type – model).  Ironically enough, I can select the surface pattern line but I cannot move it or align it like I can when the material is applied to something else (like a wall).  I have tried unpinning the curtain wall panel but that does nothing for me.  I am working in Revit 2014 Onebox.  I have attached a file containing the family. Thanks for any help.
Tue, Nov 19, 2013 at 8:12:18 PM | Curtain wall panel surface pattern
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
select a panel -> unpin -> edit InPlace -> apply marerial -> align pattern -> finish... for all panels.
Or, if it's annoying, make a custom panel component family with aligned materal.
Or, make all panels separately with other curtain wall type and apply it as panel instead.
 here is a post about it.
http://plevit1.blogspot.kr/2013/09/make-curtain-wall-smart.html
Hope it helps.
Edited on: Tue, Nov 19, 2013 at 8:17:29 PM
want more?
You can get more tips at Enjoy Revit
Wed, Nov 20, 2013 at 8:39:09 AM | Curtain wall panel surface pattern
RockFish
5 Stars: 2 Votes
Thanks, I did not realize you could edit a panel in place.  I checked out the link and also picked up the trick of creating elevations from assembly view (very nice).  I had seen the earlier post about curved pattern mapping through Jeffrey Pinheiro’s blog but didn’t realize you had a blog yourself (I am guessing you and the blog poster are one in the same).  I guess I have a new blog to add to my list.  Thanks again for the help.
Wed, Nov 20, 2013 at 9:08:32 AM | Curtain wall panel surface pattern
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
yes. i'm the one who running the blog, Enjoy Revit. and glad to help.Don't miss any of little tips there. Smile
want more?
Parametric Curtain wall panel in divided surface
Sun, Jan 31, 2010 at 8:08:55 AM
Surface orientation in panel by pattern
Thu, Apr 24, 2014 at 6:02:35 AM
Surface pattern wont align
Sun, Nov 9, 2008 at 3:16:05 AM
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:58 AM
Curtain Wall Panel to Curtain Wall Door
Mon, Jun 23, 2014 at 9:32:12 AM
Page generation time: 1.1894
