Forums >> Revit Systems >> Technical Support >> Parameter Formulas and "Grips"
9 Posts No Rating |
Is it possible to have a parameter with a formula AND "grips"? Or is this just a wishlist item? If so, what is the process?
setver62 |
I don't understand how that would work. You can have grips (instance based parameter) or you can use a formula using other parameters.
Maybe a better explanation of what you want would help.
9 Posts No Rating |
Just want to know if you can have a formula and still get grips for that parameter. I am trying to create a parameter that uses a formula when inserted, or other parts are modified, but it can also be modified with grips. The grip modification would also feed back to the formula for final modification.
I have a face-based family (required for my needs) that needs an extrusion that stretches in 2 inch increments. If there is a way to either embed a line-based array family in the family I have, or a way for the face-based family to have this feature, that would eliminate the need for a formula.
Thanks in advance...
setver62 |
It sounds like you need to do exactly what I did with a shelving unit family. I ended up using two parameters and two reference planes. The first parameter would be Length_Adjust, and would be tied to a the first ref plane set as a weak reference. This will give you a set of grips you can adjust in the plan. The second parameter would be Length_Actual, and would be tied to the second ref plane set as not a reference. The family geometry is tied to that ref plane. The Length_Actual parameter contains your formula, and reads Length_Adjust.
Hopefully that's clear enough for now, I don't have time to post a family or formulas.
9 Posts No Rating |
Thanks, I'll try that.
setver62 |
Door Family Formulas |
Fri, Dec 12, 2008 at 3:00:48 PM
instance parameter without shape handles |
Fri, Aug 31, 2007 at 6:48:46 AM
"Group parameter under:" |
Wed, Aug 22, 2018 at 10:42:29 AM
11
basic formula question regarding parameter use |
Wed, Jun 16, 2010 at 5:34:24 PM
"can't find solutions for formulas" error |
Wed, Aug 3, 2016 at 5:46:22 PM
Members: | 2098116 | Objects: | 23164 | Forum Posts: | 152290 | Job Listings: | 3 |
