Forums >> Revit Structure >> Technical Support >> walls wont attach to new roof
16 Posts No Rating |
I needed to amend the roof to my house model so I deleted the roof from my model.
I have now added a new roof but now the walls wont attach to the new roof
Any ideas why??
Thanks
Because your roof is not really over the walls. Cut a section and look.
Hi
I am not sure what you mean. I redid the roof by picking the walls and adding overhangs, as I did with the previous roof.
Now if I look on an elevation there is a gap between the top of the walls and the new roof
Did you click on the wall and then tell it to attach to the roof? It won't do it automatically unless you tell it to.
Yes I did that but the wall stays the same ie does not go up to the new roof
Either the roof is not over the wall or you did not attach it.
Did you edit the wall profile? If so, then that will not attach.
No I didnt change anything on the walls. All I did was delete the roof (where the walls were already successfully attached before I deleted it)
Then I added a new roof by using the footprint/pick walls.
Post the section I asked you to cut perpindicular to the wall. Include the wall properties.
ok but I will have to wait until tomorrow as I only have software at work.
thanks so far
