57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Custom divide surface pattern?
Sat, Nov 16, 2013 at 3:17:12 PM | Custom divide surface pattern?
jpmays23
I am aware of the standard patterns available in a conceptual mass for creating curtain systems (hexagon, octagon, rectangle, etc.).  Is it possible to create a custom pattern, or to modify one of the standard ones?  I am trying to make a herringbone pattern usinf Revit 2014.  Thanks.
Mon, Nov 18, 2013 at 10:22:34 PM | Custom divide surface pattern?
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
You can make most of patterns with basic patterns in revit.
And when you choose one, shape of mass must be considerd. If  the mass has flat facade, basic rectangle pattern will be enough to make what you want.
want more?
You can get more tips at Enjoy Revit
Mon, Nov 18, 2013 at 10:37:33 PM | Custom divide surface pattern?
jpmays23
This is a simplified version of what I'm trying to do.  How can I achieve this with a simple rectangular pattern?  Thanks.
Mon, Nov 18, 2013 at 11:14:27 PM | Custom divide surface pattern?
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
See attached image.
hope it helps
want more?
Wed, Jan 22, 2014 at 4:14:59 PM | Custom divide surface pattern?
hamedmahone
hi everybody , how can i create this pattern regarding divide surface?
Created forms and divide surface tools
Wed, Jan 1, 2014 at 4:34:46 AM
Divide Surface of conceptuall mass by level?
Wed, Jan 13, 2010 at 5:23:14 AM
voronoi surface pattern
Fri, Jun 24, 2011 at 2:14:03 PM
Creating irregular patterns with divide surface
Fri, Sep 28, 2012 at 10:00:35 AM
Custom Surface pattern.
Wed, Jun 2, 2021 at 2:14:47 AM
Page generation time: 0.7902
