37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Missing Third Party Extension
Fri, Nov 15, 2013 at 7:49:42 AM | Missing Third Party Extension
eluttmann
Hi all,
I am getting the error message (attached) that the model is "Missing Third Party Extension". I am unsure how this happened, and what needs to happen to fix it?
Thanks.
Fri, Nov 15, 2013 at 7:54:38 AM | Missing Third Party Extension
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to tell us more about what the extension is and what you are doing.  The images look like AutoCAD not Revit
Fri, Nov 15, 2013 at 7:58:55 AM | Missing Third Party Extension
eluttmann
I am not sure what the extension is as I have not seen this happen before. It pops up every time I open the model, and does not reappear until the next time I open the model. It is REVIT Building Design Suite 2013, and I have structural engineers working in the model as well who have not seen this extension before.
Fri, Nov 15, 2013 at 8:10:44 AM | Missing Third Party Extension
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Check out this post. It suggests that somebody who is working on your model with you has a 3rd party application that they used and since you don't have the app or extension you are getting the error.
http://forums.autodesk.com/t5/Revit-Architecture/Third-Party-Updater-Error-Message/td-p/3564050
Fri, Nov 15, 2013 at 8:14:51 AM | Missing Third Party Extension
If you are architectural or MEP and your structural people are working in the same model, then be aware that this can cause you performance problems as well as other issues.  Revit was built to keep these disciplines seperate.
MISSING THIRD PARTY UPDATER - 2013 error message
Tue, Aug 6, 2013 at 9:09:34 AM
2016 Revit Lt Timber Extension?
Thu, Sep 24, 2015 at 8:37:07 PM
Revit 3rd Party Artistic Addons
Wed, Jul 4, 2018 at 7:25:13 PM
Opening Up Installed Third Party AddIns
Mon, Feb 10, 2014 at 11:10:09 AM
3rd party to build Revit families
Thu, Dec 18, 2014 at 10:03:47 PM
Page generation time: 0.4174
