25 Users Online (24 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> transparent backlit wall
Thu, Nov 14, 2013 at 9:15:06 AM | transparent backlit wall
choona
choona Avatar
HI,
I am doing a coffee shop project and for its interior I need to creat backlit wall which has light and an image on the surface, so I tried to creat 2 layer finishes for the wall, for  first layar (a layer under last finishes) I choose lighting material and  raise the number of transpancy, for the second one, I choose an image that has texture  and again raise the trancparency.but didn't work. any help??
another thing  is if i want to creat a colorful wall like a semi transparent glass and put light inside of that, how should i do?
thanks-
Fri, Nov 15, 2013 at 12:48:56 AM | transparent backlit wall
ronmalit
5 Stars: 3 Votes
Hi Choona
the correct way to do this is like how you do it in 3ds Max or you who will construct it on site.
create the wall with your desired panel thickness. lets say 20mm
create a material add map your appearance image, self-illumination, transparency or cutout (do a search from your help file if you are not sure what to use)
download/create and place a lighting fixture behind it.
this applies to your second question also.
** dont be mad, i dont have much... i am homeless
Thu, Nov 21, 2013 at 2:31:47 AM | transparent backlit wall
choona
choona Avatar
thanks  ronmalit ,I  will do that and i tell the result
creating backlit glass in renderings
Sat, Feb 23, 2013 at 6:15:07 AM
Walls with 2" airs space on inside, whole wall is transparent form insed view?
Wed, Mar 12, 2014 at 3:45:22 PM
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
Making a demolished wall transparent
Mon, Jan 24, 2022 at 6:22:30 PM
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:06 AM
Page generation time: 0.7164
