68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Precast Panel Schedules for Shop Drawings
Thu, Nov 14, 2013 at 12:52:23 AM | Precast Panel Schedules for Shop Drawings
dasher77
5 Stars: 2 Votes
Hi there, I have just started working with a company moving over to revit. They would like me to create a sheet that would load the relevant details for a panel(dims, volume, weight, etc) when the drawing is placed on the sheet. They have a panel per sheet. I cant do it with title block family, I know I can get the data with a schedule, but to load the data for each panel as it is dropped onto the sheet? I am at a a loss, and hoping I am making sense?? Can you even do this, or do you just need to make up a schedule per panel and place that on the sheet as well? If you can help that would be awesome. Thanks
Fri, Nov 15, 2013 at 1:19:52 AM | Precast Panel Schedules for Shop Drawings
ronmalit
5 Stars: 3 Votes
Hi Dasher77
how about you use a tag with no leader? so you can drag it away from your element and near the notes area so it will look like part of the sheet?
-place all your view on your sheet
-select one view, activate it and tag the element (no leader)
-drag the tag to your desired position, use guidegrid so that all the tag will be aligned on all the sheets.
** dont be mad, i dont have much... i am homeless
Precast Panel / Dado panel - Wall Schedule to issue drawings for shop detailing.
Tue, Sep 30, 2014 at 7:03:42 AM
Precast Concrete Shop Drawings
Fri, Apr 10, 2020 at 2:08:55 AM
Using Revit MEP to make ductwork shop drawings
Wed, Jun 15, 2011 at 9:52:03 PM
precast shop ticket Revit 2010
Fri, Jan 14, 2011 at 8:16:17 PM
Custom Precast Family
Fri, Mar 18, 2016 at 2:48:13 PM
Page generation time: 0.7454
