101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> make elevation cut line show from diffrent planes
Thu, Feb 16, 2006 at 12:48:13 PM | make elevation cut line show from diffrent planes
dvsone78
I have a retaining wall thats showing up in my elevation and i dont want it to is there a way to make the elevation cut line jog and then cut back around the wall.
Thu, Feb 16, 2006 at 1:19:30 PM | RE: make elevation cut line show from diffrent planes
quiller
quiller Avatar
2.5 Stars: 3 Votes
You can use a section and split it, but you can't do this with elevation. See the attached for more details
Thu, Feb 16, 2006 at 7:38:05 PM | RE: make elevation cut line show from diffrent planes
dvsone78
Thank you i figured that out about 2 mins after i posted this since i got no answer on the multi sloping drive way maybe you know how to do it.. i need a driveway that slopes away from the street and also that slopes with the street.
Thu, Feb 16, 2006 at 7:40:24 PM | RE: make elevation cut line show from diffrent planes
dvsone78
here is the image to help maybe.
Thu, Jul 9, 2009 at 2:05:39 PM | make elevation cut line show from diffrent planes
aking05
Is there a way to do this in plan?  I have 2 buildings with Finish floors at different elevations.  Is there a way to show them on the same plan with them both cutting at 4' AFF?
Thu, Jul 9, 2009 at 2:10:05 PM | make elevation cut line show from diffrent planes
Use plan regions... read about them in your H E L P
Grade Lines in Elevation view not showing
Fri, May 25, 2007 at 5:49:36 PM
Stair shading at cut line. Rvt 2011
Tue, Oct 4, 2011 at 8:22:27 PM
elevation start point
Fri, Mar 24, 2006 at 8:40:45 AM
Elevation Cut Plane
Tue, Jul 9, 2013 at 3:46:47 PM
Stair above cut line question
Tue, May 6, 2008 at 10:50:29 AM
Page generation time: 1.9073
