99 Users Online (98 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2014 - Schedules - Hiding Zero Values
Tue, Nov 12, 2013 at 6:36:47 AM | Revit 2014 - Schedules - Hiding Zero Values
SB84
HI,
 I have two parameters in my schedule - Scheduled Area (manually inputted area) and Actual Area (the revit measurement) in sqm.
I then have a calculated value to work out the difference between them. In the calculated parameter I also have an IF function so that it only calculated the difference if the Scheduled area is not 0sqm.
This is because we have a SoA with specific areas for many of the rooms. However, many of them do not have areas as they are "to the architect's design" i.e Toilets. We need to be able to calculate the difference between the total of the scheduled areas and our total for those areas (excluding the rooms that didn't have scheduled areas.) So we can prove how close we are to the scheduled area. (BID requirement)
Using the IF function I can get it to only work out the difference if the value is over 0sqm - however, to get it to work I have to tell it to put a value of 0 for those rooms without a scheduled area as Revit needs a value when the parameter is a number/length/area etc.
Does anyone know a work around for this? In Excel you can get it replace 0's with blanks quite easily but Revit doesn't want to.
Current Calculated Parameter - If(Scheduled Area  > 0, (Actual Area - Scheduled Area Total),0)
Have a feeling I know the answer but thought I'd try..?
Thanks in advance
Tue, Nov 12, 2013 at 5:15:46 PM | Revit 2014 - Schedules - Hiding Zero Values
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If you are trying to leave the field blank rather than producing a placeholder '0' then I think you're out of luck.
Wed, Nov 13, 2013 at 6:11:40 AM | Revit 2014 - Schedules - Hiding Zero Values
SB84
Yeah I thought so. There's a way in excel of producing blank cells - hopefully Revit will get somewhere near the functionality of excel eventually!
Revit 2014 schedules... where did the Show button go?
Mon, Dec 16, 2013 at 2:18:43 PM
Fixed values in schedules
Mon, Jul 9, 2007 at 10:34:14 PM
Cursor not visible in schedules, Revit Structure 2014
Tue, Apr 29, 2014 at 2:16:15 PM
Preloaded Size Values in Revit MEP
Tue, Aug 24, 2010 at 1:54:48 PM
Hiding Rows in Schedules
Thu, Aug 7, 2008 at 2:47:36 AM
Page generation time: 1.7642
