70 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2014 Area Numbering
Fri, Nov 8, 2013 at 11:09:29 AM | Revit 2014 Area Numbering
creed1982
1st post...
We have recently upgraded to Revit 2014 and are currently in the process of taking old projects (done in Revit 2010) and upgrading them to 2014.  When adjusting the areas, we noticed that when we select the area, its boundary, and tag, and move it around on the area plan, the area number changes.  We have all the areas numbered for filtering reasons, so this is problematic when there are 30+ areas to have to go back and renumber.  Is anyone else having this issue/have a solution?  We've already deleted out any "unplaced" areas, in case that matters.  Thanks for any response.
Fri, Nov 8, 2013 at 11:35:37 AM | Revit 2014 Area Numbering
I don't believe you are moving the area.  Redraw - move your boundry.  Then make sure you don't have disjoin on and move the area.  The tag will move if you let it.
Area Plans - Revit 2014
Thu, May 29, 2014 at 12:21:33 PM
Stair numbering
Tue, Feb 27, 2018 at 4:34:51 PM
Revit addins - Revit 2014 door and room renumbering
Thu, Jan 2, 2014 at 11:31:52 AM
Revision Numbering
Thu, Jun 18, 2015 at 2:33:41 AM
Revit Area Plan - Furniture & walls are showing area hatch
Fri, Mar 20, 2015 at 12:21:21 AM
Page generation time: 19.4906
