40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Door not cutting joined wall
Thu, Nov 7, 2013 at 5:51:06 PM | Door not cutting joined wall
SBme
So I have a regular bathroom wall and I added a 4' high ceramic tile wall. I joined the walls and put a door in. Problem is door is not cutting through the tile wall, only the gyp. bd. wall. If I extend the tile wall above the door, it cuts through it fine, but that's not what I need.
I could've sworn this worked properly before. Any ideas?
System: Revit 2014 (update release 2) on Quad-Core Thinkpad w/ 64-bit Win7 & 8Gb Ram.
Thu, Nov 7, 2013 at 5:58:38 PM | Door not cutting joined wall
SBme
Ok, so this is weird. I took the tile wall up to ceiling and the door cut throught the tile wall. Then, just for the sake of trying, I brought the tile wall incrementally down to 4' and lo and behold the door is cutting it fine.
Happy that it's working, but would like to know how to make sure it doesn't create problems in the future. Ideas?
Thanks
Fri, Nov 8, 2013 at 7:20:42 AM | Door not cutting joined wall
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you have the latest updates installed on Revit?  That is usually the best place to start.
Mon, Nov 11, 2013 at 8:57:08 AM | Door not cutting joined wall
SBme
Yes I do have the latest. Just went thgough this with my last post. Everything is currently up to date.
Tue, Feb 13, 2018 at 1:11:47 PM | Door not cutting joined wall
bocube
Revit 2018 - still lthe same issue - and still the same solution. Thank you!
Tue, Feb 13, 2018 at 4:56:52 PM | Door not cutting joined wall
Join the walls again.
Wed, Feb 14, 2018 at 12:54:55 PM | Door not cutting joined wall
sllana
5 Stars: 2 Votes
That's why I laugh at artificial intelligence. Or maybe guys at autodesk already know how to make doors to cut all walls encountered but they leave it for future releases for comercial purposes.
door opening cutting parallel wall
Mon, Sep 15, 2008 at 2:54:11 PM
window not cutting joined roof
Mon, Mar 6, 2017 at 4:23:51 PM
door not cutting wall
Mon, Apr 6, 2015 at 10:24:33 AM
Opening Tool in JOINED Walls
Thu, Jul 22, 2010 at 6:18:38 AM
Wall Base/ Wall Sweeps and Door "Clipping/Cutting" RVT 2014
Fri, Jul 8, 2016 at 12:35:15 PM
Page generation time: 1.0496
