Forums >> Revit Building >> Technical Support >> Help on Grid Label
I have a Grid Family with two information, Grid Name and Building Name, I have them combined in one label. The question is how can I put underline on the Grid Name without the Building Name parameter be affected.
Is it possible to use two separate labels with different text types. Or what about drawing a line?
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Just use reulart text, use underscores and use a text font and size that will keep the underscores tight together so that they look like a single line like this
http://www.revitcity.com/forums.php?action=viewthread&thread_id=10856
this workflow will make the grid bubble display in elevation in horizontal alignment. it is supposed to be have the same view as per plan.
@archigraphics. i think that is not possible.
It's possible to have 2 or more labels per grid head family (to separate parameters and text styles). It's possible to have different grid head families applying to different axis (to deal with the auto-rotation that revit makes when the axis is horizontal).
Marc Faber
Column Grid Text |
Tue, Dec 11, 2007 at 9:33:37 AM
Change Section Header Label size |
Thu, Apr 8, 2010 at 10:37:06 AM
Partial Label Annotation |
Mon, Apr 20, 2015 at 10:14:21 AM
Grid Bubble Labeling Issue |
Fri, Jan 15, 2010 at 3:43:18 PM
Label location flexible |
Thu, Oct 13, 2011 at 4:42:23 AM
Members: | 2106034 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
