Forums >> Revit Building >> Technical Support >> Rotate Floor Plan without rotating project
6 Posts No Rating |
Anybody know anyway to rotate or mirror specific views on a sheet without rotating the whole model?
You have two methods available. Rotate view and rotate view on sheet. You can read how to do each in your HELP.
Edited on: Mon, Nov 4, 2013 at 11:49:26 AM
6 Posts No Rating |
thanks.. any ideas on how to Mirror?
How to mirror what?
You can mirror objects.
You can mirror project. << Read about that in your HELP as well.
Mirroring a Project
Mirroring a project allows you to mirror (reflect the placement and shape of) all elements in a project around an axis you select (North - South, East - West, Northeast - Southwest, or Northwest - Southeast). When you mirror a project, model elements, all views, and annotations are mirrored. Orientation of annotations is preserved when necessary, for example text does not mirror in order to retain readability.
6 Posts No Rating |
"How to Mirror what?
I want to mirror a view on a sheet. For example I want to show 2 versions of the same floor plan but one is a mirror of the other.
Sorry - this is not CAD. Views are model based - not just lines like CAD.
You would have to mirror project, then link the mirrored project in (new location) and use linked view. That will work.
6 Posts No Rating |
Right.. Thats what we currently do and its a maintenance nightmare, but its interesting that you can rotate a view but not mirror it!
Nothing "interesting" here. Rotating a view is just that.... doesn't mess with model - just changes the point of reference. But a mirror is completely different.
I don't understand why it is a nightmare? Is it because of changes? Just re-mirror the project and reload the link - done.
Rotating a Project |
Thu, Jun 29, 2006 at 9:08:00 AM
rotating spot elevations on plan |
Fri, Mar 6, 2015 at 12:14:14 PM
How to Rotate True North without rotating the whole Project? |
Thu, Mar 18, 2010 at 7:25:35 PM
Components not rotating with project |
Fri, Feb 16, 2007 at 10:19:33 AM
Rotating Views |
Wed, Aug 21, 2013 at 11:12:42 AM
Members: | 2116494 | Objects: | 23196 | Forum Posts: | 152298 | Job Listings: | 3 |
