39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> dwg elevated points can't create topo in Revit
Fri, Nov 1, 2013 at 1:04:34 PM | dwg elevated points can't create topo in Revit
hifrank001
hello, I have a dwg by surveyor but all points are at the same level; so I raised them individually in CAD;
then I linked this file in Revit but toposurface didn't recogenized these points.
I guess the way I elevated points in CAD is not how CIVIL 3D makes, but it did take me a good hours.
Any suggestion?
Fri, Nov 1, 2013 at 1:07:04 PM | dwg elevated points can't create topo in Revit
3.5 Stars: 395 Votes
You don't say what you did in CAD.  If you had points in a CSV file, those can be used.  Otherwise, if the CAD file has contour lines, simply changing the Z of those lines is the way to do this.
I would ask the surveyor for his points file.
Edited on: Fri, Nov 1, 2013 at 1:07:35 PM
Mon, Nov 4, 2013 at 1:54:06 AM | dwg elevated points can't create topo in Revit
Thread Post Kudo! #3
ronmalit
5 Stars: 3 Votes
HI Hifrank001
you posted a TOPIC regarding autocad points not being recognized by revit, and lets talk about it.
read this link and might solved your problem: http://forums.augi.com/archive/index.php/t-36503.html
it has helped me couple of times already as we dont have civil3d on hand as well.
"Points aren't recognised unfortunately. Doesn't matter what node point symbol you assign to them in AutoCAD."
there is a GENTOPO lisp that add circles into those points.
then when you create topo in revit, always select the newly created layer that contains those circles.
i feel you! as on our side, we cant always ask for the things we need from subcons just for the reasons that revit cannot do this and that.
but if GENTOPO still cant help you, then you try other suggestions/options
** dont be mad, i dont have much... i am homeless
Fri, Nov 8, 2013 at 1:04:35 PM | ronmalit
hifrank001
Quoting ronmalit from 2013-11-04 01:54:06
" you posted a TOPIC regarding autocad points not being recognized by revit, and lets talk about it.
thanks, ronmalit ; this works very well. Just curious why they didn't do it in short line instead of circle.
Edited on: Fri, Nov 8, 2013 at 1:05:20 PM
Edited on: Fri, Nov 8, 2013 at 1:05:41 PM
Fri, Nov 8, 2013 at 1:06:31 PM | WWHub
hifrank001
Quoting WWHub from 2013-11-01 13:07:04
"You don't say what you did in CAD.  If you had points in a CSV file, those can be used.  Otherwise, if the CAD file has contour lines, simply changing the Z of those lines is the way to do this.
 I would ask the surveyor for his points file.Edited on: Fri, Nov 1, 2013 at 1:07:35 PM"
I changed all points' eleavation "Z". thanks,
Topo Surface using ACAD dwg
Fri, Jul 7, 2006 at 2:13:08 PM
Topo
Sat, Sep 27, 2008 at 12:05:04 PM
Elevation of Topo points
Tue, Nov 7, 2017 at 10:20:45 AM
Exporting topography points from Revit to AutoCad
Sat, May 23, 2015 at 11:21:41 AM
Create topography from instance not picking up points
Wed, Jan 30, 2013 at 9:51:10 AM
Page generation time: 2.7053
