34 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2013/2014 Linear Pendant light fixture
Fri, Nov 1, 2013 at 10:19:17 AM | Revit 2013/2014 Linear Pendant light fixture
jmqrsq
5 Stars: 3 Votes
Has anyone figured out the best way to create a face-based (to host to a linked model ceiling or sloped roof or sloped structure) and have it always be vertical yet have the two seperate pendant mounts automatically change heights? I have tried creating a lighting fixture, non - hosted and nesting that into a generic model face based family, then changing the category to light fixture. The family still orients to my sloped roof and structure so that wasnt the answer. I have scoured the web for any latest information on this and usually when you do a search for revit how to's and there is none it means that it cannot be done currently. Well anything can be done if given the appropriate time I just never seem to have that when coming accross a family I need to build fast. Project deadlines suck. =)
I am not necessarily asking someone to build me a family, just share your methods so I can recreate the dream.
Thanks
Fri, Nov 1, 2013 at 10:45:45 AM | Revit 2013/2014 Linear Pendant light fixture
One problem is "always vertical" is in relation to the host.  The second problem is the changing length required.  You can't get two automatic controls.
I think you simply built a faced based family that will attach to the ceiling.  Build the base normal to the host.  Then have a  reference line from that connection at a type set angle to the host face.  Add your drop geometry along the angled with an instance based length.  Place a nested light fixture at the bottom of the drop.  Angle controlled by the angle parameter.
Now you should be able to host the type driven angled fixture and adjust the drops.....
WHOA! That only works with ceilings sloping in one direction.... An even better method.
Create a work plane based family with the light set to the work plane and each drop (above) independently set with instance lengths on each drop.  This one will work with mounting in any direction.
Linear Wall Washer Pendant
Tue, Aug 11, 2015 at 12:21:01 PM
cannot fiure out how to make linear light fixure give off linear light
Tue, Jun 16, 2009 at 10:24:58 AM
Linear lighting fixture
Wed, Sep 2, 2009 at 2:32:09 AM
Linear lights aren't linear at all?
Fri, Feb 4, 2011 at 1:54:02 PM
Light source inside the light fixture
Fri, Feb 22, 2013 at 7:24:33 AM
Page generation time: 2.2340
