84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Populate Revisions in Title Block
Thu, Oct 31, 2013 at 3:52:32 PM | Populate Revisions in Title Block
dustybottoms7436
Is there a way to show Revision 1, say "Issued for DD" to every sheet easily without needing to have a revision box of that revision number somewhere on the sheet.
I know the revisions box automatically populates as revision clouds are on the sheet, but I'd like to have it filled out without needing to put a revision cloud on every sheet.
Fri, Nov 1, 2013 at 7:24:24 AM | Populate Revisions in Title Block
We put a very small cloud down near the sheet number.  Then we select that and over-ride graphics in view to white.  I wish you could copy paste that with the over-ride but it will not.
We have a separate spot on our titleblock for issues.  That's where we say "ISSUED FOR XXXXX".  Once it is ISSUED FOR CONSTRUCTION, we don't change that anymore.  I don't believe this should be a revision item.
Wed, Nov 13, 2013 at 12:50:47 PM | Populate Revisions in Title Block
gbiallas5728
There is a Revisions on Sheet property that allows you check the revisions you want to display in the revision schedule if there are no clouds on the sheet.
Wed, Nov 13, 2013 at 2:20:01 PM | Populate Revisions in Title Block
gbiallas,  The setting you describe is not available if you do revisions by project.
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:26 AM
Missing Delta Symbol in Title Block Revisions/Issues Log
Fri, Sep 5, 2014 at 7:12:30 AM
Adding a more than 3 revision labels in title block
Fri, Nov 4, 2011 at 3:22:52 PM
Title Block Revisions Question
Tue, Oct 7, 2014 at 7:16:21 AM
Sketch Title Block Masking issues
Wed, Nov 28, 2012 at 10:35:09 PM
Page generation time: 0.3140
