51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Filtering curtain panel schedule by type
Thu, Oct 31, 2013 at 2:25:57 PM | Filtering curtain panel schedule by type
ctrain51
Hello,
I am trying to calculate the area of curtain systems applied to a mass for a preliminary pricing package, but it doesn't appear that you can schedule the area of a curtain system, only curtain wall.
So my workaround is to schedule the areas of all of the differnt panels. I can create a curtain panel schedule easily enough, but I can't seem to filter it by type. I have twelve different panel types, and I want to create one schedule for each type, but I can't figure out how to filter by type, it's not an option. I can only create one giant schedule with every type listed.
Is there a way to do this that I haven't figured out?
p.s. if there is a way to schdule the area of a curtain system, I am all ears on that as well.
This is for version 2014.
Thanks!
Edited on: Thu, Oct 31, 2013 at 2:31:09 PM
Thu, Oct 31, 2013 at 3:32:21 PM | Filtering curtain panel schedule by type
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
maybe add in "type comments" and then filter using that parameter...
then hide the column for your final output.
Mon, Nov 4, 2013 at 9:10:41 AM | Filtering curtain panel schedule by type
ctrain51
That worked perfectly, thank you!
Schedule curtain panel by level?
Fri, Sep 2, 2016 at 4:40:26 PM
Panel selection in curtain walls
Tue, Jul 22, 2014 at 4:54:07 PM
curtain panel door not reading completely in schedule
Thu, Jun 30, 2011 at 1:56:59 PM
curtain panel glass type
Sun, May 30, 2010 at 6:05:40 AM
Scheduling "System" Curtain Walling Panel Parameters
Thu, Aug 28, 2014 at 9:35:37 AM
Page generation time: 8.5870
