Forums >> General Discussion >> Revit Project Management >> Revit 2014 to Artlantis 5
11 Posts No Rating |
Hello...
I've successfully installed Artalntis 5.0.2.3!
I work with Revit Architecture 2014, and i tried to install the plugin Revit_2014_to_ATL5_Win64.
The main issue is that, after successfully installation of plugin, when i open Revit, it doesn't show on the ribbon (Addins Tab).
Any ideas what's wrong with the plugin? Or if someone is running ok with this plugin?
Cheers
Is the plug-in saved in the correct directory? If it is then you are better off contacting Artalntis and asking them.
I have only done the setup.exe..and it was saved on the default folder..wiitch folder should it be?
The default folder is C:\ProgramData\Autodesk\Revit\Addins\
There is no option to choose the directory or folder when i install artlantis plugin, how to change it?
hi, I’m using Revit 2015 and trying to render it with Artlantis 5, but it too slow, since i used to work on Arhcicad 16 and render it with the same Artlantis which was much faster... please help… what I’m I doing wrong.
Artlantis |
Tue, Apr 8, 2014 at 6:43:56 AM
Artlantis 6.5 for Revit has arrived! |
Wed, Feb 1, 2017 at 10:48:31 AM
Revit Building 9.1/Artlantis |
Thu, Apr 16, 2009 at 3:10:05 AM
PLEASE HELP! Revit + Sketchup intol Artlantis |
Sat, Jun 7, 2014 at 6:26:28 AM
13
artlantis renderer 2.1 + revit 2010 |
Wed, Jun 17, 2009 at 10:22:58 AM
11
Members: | 2105574 | Objects: | 23178 | Forum Posts: | 152303 | Job Listings: | 3 |
