Forums >> General Discussion >> Revit Project Management >> REVIT LT 2014 vs REVIT 2014
72 Posts No Rating |
I checked a few threads on here and didn't see many disccusions on the differences between the two, for starters here is how Autodesk compares them
http://images.autodesk.com/adsk/files/revitlt_2013_faq_final0.pdf
http://www.autodesk.com/products/revit-lt/compare/compare-revit-products
Feel free to discuss things you have noticed here !
I am still shopping around for software and it seems Revit LT would fully suit my companies (fabricator) need at this time, but my biggest concern which might be a deal breaker for LT is I won't be able to add any Third-Party add ons like MWF Pro Wall? (which we would get if we did get Revit)
Is this absolutely positively true? If so that stinks!
Edited on: Wed, Oct 30, 2013 at 2:07:02 PM
----------------------------------- Imagination reveals truths reality obscures. |
The comparison says LT has no API - so no add-ins.
No components stuff either which I think you will want.
This user is online |
Thanks, that's what I thought, just wanted to confirm.
and what are components again? sorry been a while haha
40 Posts No Rating |
I'm working in Revit Architecture LT because we are a small firm and Revit full is expensive. We are also just starting with BIM.
Yes there are no ad ons, you need full for this. Absolutly. Some third parties claim they have ad ons for LT, they don't work.
There is no rendering.
There are no "in place masses" available.
Structural tools are greatly reduced in the Architecture Version and there is no option for framing elevations.
Autodesk actually does not list all the limitations put on LT, you have to dig around the web for them.
Here are a couple more links for you.
http://www.thecadmasters.com/wordpress/index.php/2013/02/22/revit-vs-revit-lt/
http://www.bimblog.ca/2012/09/revit-lt-light-or-right.html
Opening a 2015 drawing in Revit 2014 |
Tue, Jul 29, 2014 at 9:11:58 AM
How to import sketchup models into revit 2014 |
Fri, Aug 5, 2016 at 9:29:15 AM
Revit 2014 - floor transparency and the linework tool |
Thu, Jan 9, 2014 at 10:38:52 AM
exporting from 3d max 2014 to revit 2014 |
Mon, Apr 28, 2014 at 6:09:26 PM
2013-2014 |
Fri, May 24, 2013 at 7:22:40 AM
Members: | 2105459 | Objects: | 23178 | Forum Posts: | 152308 | Job Listings: | 3 |
