Forums >> Revit Building >> Technical Support >> Detail bubble callout lineweight
2 Posts No Rating |
In Revit 2014, is there a way to change the lineweight of the detail bubble callout so it has more pop?
on your property browser look for family/callout head/right click and edit
in the family editor go to manage/object styles/modify subcategories/new/create and assign lineweight and line color
select the existing lines and change the subcategory to the newly created thick lines.
and um i forgot, load the new callout head and dont forget to duplicate/create new call out tag and assign the new head.
Edited on: Tue, Oct 29, 2013 at 1:28:57 AM
** dont be mad, i dont have much... i am homeless |
ronmalt, I don't believe your process is correct.
The question I think was about the callout "bubble". If they meant the boundry, then that is easily controlled through the manage/objects styles tab. If they meant the "callout head", then that too is best controlled through this same location. This will cange all callout heads. If they truely want a different head just for this callout then your process will work but .......
2 Posts No Rating |
The boundary is what I was questioning and your directions gave me the result I needed. Thank you!
DETAIL BUBBLE - editing system families |
Tue, Feb 2, 2010 at 7:08:10 PM
Callout Bubble LWT change |
Wed, Jan 9, 2008 at 4:00:50 PM
Detail Bubble Callout Options? |
Thu, Aug 13, 2015 at 3:54:17 PM
Detail Callout Issue |
Tue, Jan 25, 2011 at 12:57:36 PM
Detail Callout Bubbles and Dependent Views |
Thu, Aug 12, 2010 at 6:51:10 AM
Members: | 2119230 | Objects: | 23205 | Forum Posts: | 152300 | Job Listings: | 3 |
