41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Purged unused and now all of my materials are missing
Mon, Oct 28, 2013 at 10:49:18 AM | Purged unused and now all of my materials are missing
MarieWilli14
I am working on a fairly complex revit project. My file was getting very large, so I purged unused to save some memory. Now, everytime I reopen my file all of my materials are missing. When I go into my materials manager the images that I have custom created are not there and I have to remove the image so that I can reupload the image. As soon as I do this, the material reappears where it was supposed to be. This is extrememly tedious and is wasting a lot of time. Is there anyway to fix this so that the materials will stay put?
Mon, Oct 28, 2013 at 11:00:04 AM | Purged unused and now all of my materials are missing
You don't say what Revit and what update you are on so is this an issue?  Please let us know.  If up to date then report this problem to autodesk.
I never purge unused without reviewing and editing what gets purged.  You should do also.
If you have a pre-purge copy of your project, you should be able to transfer project standards.... and ONLY pick the pmaterials.  If you don't have a copy then you've learned another lesson.
Mon, Oct 28, 2013 at 11:43:17 AM | Purged unused and now all of my materials are missing
MarieWilli14
My software is up to date.
I will admit that I did not review what I was purging prior to starting it.
My issue now is that my materials are missing every time I reopen my file. I have recreated and reimported my images for my materials severl times, but every time I open the file they are missing again. Is there any way to prevent this from happening? Do i maybe have a setting that could be causing this?
Post purge component problems
Wed, Jan 6, 2010 at 6:47:01 AM
purging unused makes central larger
Mon, Feb 11, 2013 at 10:36:13 AM
Recover purged families?
Tue, Feb 19, 2008 at 11:40:36 AM
Create Report of Unused Items to verify before Purge?
Wed, Jun 22, 2016 at 5:18:46 PM
Templates
Sat, Apr 9, 2011 at 8:26:51 PM
Page generation time: 0.5641
