57 Users Online (55 Members):
Forums >> Revit Structure >> Technical Support >> Material Takeoff for insulation??
![moffatt Avatar](user_avatar/494961.jpg)
![5 Stars: 2 Votes](/images/stars_5.gif) |
I get that I can make a material takeoff for general things in my design but if I wanted to find out how much insulation there would be in my house model is it possible to make a takeoff for that?
Is your material a separate layer or simply batt insulation in a cavity? You really should have told us.
- Obviously, if it is a sheet good applied as a layer, then just take that off in a material schedule.
- If it is batt insulation in a cavity, take off the area of your exterior walls. If metal studs, then that is your area. If wood studs, then you will have to factor appropriately.
it isn't a layer i was just hoping there was a tool that took the information from the wall type and calculated the insulation amounts needed
Material Takeoff |
Mon, Apr 27, 2015 at 7:32:15 AM
Ceiling Material Takeoff |
Thu, Feb 15, 2007 at 3:19:57 PM
Material Takeoff issue |
Mon, Oct 25, 2010 at 3:48:35 PM
Sheathing Material Takeoff |
Mon, Apr 25, 2011 at 7:01:06 AM
Wall Material Takeoff vs. Wall Quantity Takeoff for material description |
Mon, Mar 15, 2010 at 1:57:00 PM
Members: | 2022314 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
