97 Users Online (96 Members):
Forums >> Revit Building >> Technical Support >> Using Keynote Manager with Revit Server
2 Posts No Rating |
Does anyone know if you can use the keynote manager in tandem with a shared revit file between two firms by using Revit Server? And if so, do you just save the .txt file to your revit server and then if both firms have the revolution design keynote manager they can both edit keynotes at the same time?
I don't know how Revit server works but I know that the keynote file can only be opened and edited by one user at a time.
2 Posts No Rating |
Yes, a .txt file can only be edited by one user at a time. But if you have purchased the keynote manager it allows you to open your keynote palette in Revit and by doing so multiple users can edit the file at the same time and reload it into the central model. I'm just wondering if this works the same way when sharing it among two offices using the revit server.
Unable to Load Keynote Data in A360 project |
Thu, Mar 3, 2016 at 10:33:05 AM
Server for Worksets |
Tue, Jun 27, 2023 at 7:28:13 AM
keynote categories |
Fri, Aug 10, 2012 at 3:56:23 PM
Revit Server |
Tue, Jul 24, 2012 at 8:00:13 AM
Multiline keynote |
Thu, Jan 8, 2009 at 2:31:33 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
