28 Users Online (27 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Curtain wall door reporting wrong level
Fri, Oct 25, 2013 at 3:51:04 AM | Curtain wall door reporting wrong level
Sofus
1 Stars: 1 Votes
I had an issue with curtain wall doors reporting wrong level. My curtain wall is based on level 1 but my door reports level 2, level 2 is 300 mm. above level 1. I searched for a solution and found that others are having the same kind of problem, and no solution. Often cut/paste solves this kind of issues, but not in this case. Until I tried cut/paste in a section, and it worked! Somehow Revit does it differently when doing it in a section rather than in plan view. This solution worked for all the doors having this problem, hope someone find this little trick useful.
Reporting parameter from curtain wall door in Curtain Wall Schedule
Mon, Dec 19, 2022 at 5:44:58 AM
11
Curtain Wall Panel to Curtain Wall Door
Retaining Curtain Wall Door Scheduling Data
Thu, Jan 8, 2015 at 2:47:08 PM
Cant load Curtain Wall Door
Wed, Oct 26, 2011 at 3:41:44 PM
Revit 2011 - Curtain Wall doors on Schedule for correct level
Thu, Jun 7, 2012 at 1:22:49 AM
Page generation time: 1.6831
