77 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> View Range
Thu, Oct 24, 2013 at 2:26:08 PM | View Range
moffatt
moffatt Avatar
5 Stars: 2 Votes
I am having an issue with my view range on my main floor I have a window that has a sill height of 7' and a garage service door that is considered to be on the lower level at 0' 0" and I can't seem to get my view range correct to show them both on the main floor plan just one or the other based on what I put my view range at for instance right now I have it set as top at 10' cut plane at 5' 1" and bottom at 0' 0" and I can only see my garage service door not the window at 7' how do I get them both to show up on the main floor plan and also show up correctly on my elevation views???
Thu, Oct 24, 2013 at 2:28:50 PM | View Range
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You will probably need to use a plan region to get them both to show up if they are at different elevations.
Thu, Oct 24, 2013 at 2:33:23 PM | View Range
moffatt
moffatt Avatar
5 Stars: 2 Votes
So I put it into a plan ragion and I can adjust the view range all the same and can't seem to get it to show is there something special about using this plan region that I'm not catching?
Thu, Oct 24, 2013 at 2:34:43 PM | View Range
moffatt
moffatt Avatar
5 Stars: 2 Votes
Thu, Oct 24, 2013 at 2:37:43 PM | View Range
moffatt
moffatt Avatar
5 Stars: 2 Votes
wow I just realized to put the plan region just around my window I was missing and now I got it thank you very much for helping me
view range
Fri, Sep 7, 2007 at 2:28:04 AM
View Range
Tue, Aug 28, 2007 at 9:52:27 AM
View Range for Revit Link
Thu, Nov 12, 2015 at 7:10:18 AM
low wall not displaying correctly with view range
Fri, Aug 3, 2012 at 4:35:37 PM
In place families above the view range are still appearing
Tue, Dec 23, 2014 at 9:17:05 AM
Page generation time: 1.1179
