41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> linked CAD linework
Tue, Oct 22, 2013 at 12:11:20 PM | linked CAD linework
ledgewood33
I am having trouble with the linework reading properly. I link a CAD dwg. to my revit model and once its in my model the linework doesnt read as it does in autocad. I have dashed or hidden lines in my CAD plan and once I link it in revit they show up as solid. I am thinking it has something to do with the LTscale in autocad?
Tue, Oct 22, 2013 at 12:34:38 PM | linked CAD linework
Linetypes are set by your import template.  Read this topic in your HELP:
Setting Line Weights for Imported DWG or DXF Files
You can over-ride these settings in VG of any view.
Tue, Oct 22, 2013 at 1:24:38 PM | linked CAD linework
ledgewood33
its not the lineweight that I am having trouble with its the linetype. for instance, I am linking a CAD drawing from a consultant and in the CAD drawing there are some hidden or dashed lines. and they read as so in autocad. once I link the CAD file into revit and view it in revit the hidden or dashed lines read as solid lines.
Tue, Oct 22, 2013 at 2:39:55 PM | linked CAD linework
Johnzo142
Look under the 'imported objects' tab in your object styles and make sure the linetype for the layer your dashed lines are on is set correctly.
Tue, Oct 22, 2013 at 3:25:41 PM | linked CAD linework
ledgewood33
so I checked in the imported oblects tab under object styles. the lines in question are listed as IMPORT-file name|DASHED. that line pattern name in the same as listed in CAD.
Tue, Oct 22, 2013 at 3:46:12 PM | linked CAD linework
Johnzo142
Change it to a Revit linestyle that suits your needs.
Problem exporting view with linked CAD file
Wed, Mar 18, 2009 at 3:46:35 PM
Constraining to linked CAD file
Thu, Apr 4, 2013 at 3:09:15 AM
Linked in CAD text
Fri, Aug 16, 2019 at 8:25:11 AM
Export from Revit To CAD with RELATIVE linked files
Wed, Nov 29, 2017 at 11:00:36 AM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:57 AM
Page generation time: 0.4297
