30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Standard Way of modelling strip foundations ???
Tue, Oct 22, 2013 at 5:11:41 AM | Standard Way of modelling strip foundations ???
curtins1
I have been using Revit for about 5 years now and I have been modelling strip foundations with the slab tool. I find by using slabs it joins correctly with pads etc. but it doesn’t necessarily mean that this is the standard way of modelling this element.
I’m really just looking for your thoughts on this matter and if there is a better way to model strip foundations.
Cheers
Fri, Nov 1, 2013 at 4:55:29 PM | Standard Way of modelling strip foundations ???
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
How did you find the built in wall foundation (strip footing) tool work ?
Mon, Nov 4, 2013 at 2:09:30 AM | Standard Way of modelling strip foundations ???
curtins1
i dont normally model walls, the architect takes control of that element. For strip footings i just use the slab tool but i was wondering if there was other alternatives in which people use. The Wall foundation tool is good though.
Mon, Nov 4, 2013 at 7:38:39 AM | Standard Way of modelling strip foundations ???
Copy monitor the walls and use the strip foundation tool.
Thu, Nov 14, 2013 at 11:35:33 AM | Standard Way of modelling strip foundations ???
allen2
I use the wall foundation tool if I have walls to use. Typically we have slab turndowns on strip footings and I use the wall tool for the footing.  I make a different wall types and rename something like “ 3’-0” Cont Ftg “ and make the wall 3’-0” wide and change and rename wall types as required.
Tue, Nov 26, 2013 at 8:15:45 PM | Standard Way of modelling strip foundations ???
David2875
The strip foundation works great with a solid wall without openings, but does anyone have a preferred way to have the footing be continuous beneath the opening?  We typically have 10 to 20 ft opening where the strip footing is continuous so the slab can turn down atop it.  I've modeled this using a concrete beam before, but I'd like to get other ideas since I'm still in the novice stage of Revit.
Thanks.
Tue, Nov 26, 2013 at 8:42:29 PM | Standard Way of modelling strip foundations ???
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
How about using the footing grip to stretch it to the other side and then using the Linework tool to make the seam lines invisible. See pic.
Tue, Nov 26, 2013 at 9:00:27 PM | Standard Way of modelling strip foundations ???
David2875
Thanks.  Worked like a charm.
Wed, Nov 27, 2013 at 6:14:40 AM | Standard Way of modelling strip foundations ???
curtins1
I have started to model the foundations with in place families as sweeps. I find they work well on big projects
Brick Corbelled Foundations
Mon, Aug 9, 2010 at 8:46:12 AM
Strip Footing Tags
Thu, Jul 26, 2007 at 8:25:30 AM
Handrail Lighting LED Strip
Thu, Jan 11, 2018 at 6:31:21 AM
How to build a mobius strip in revit?
Mon, Aug 30, 2010 at 5:08:51 PM
How to Hide Door Transition Strip with Materials Finishes in RCP (Revit 09)
Thu, Sep 4, 2008 at 4:13:16 PM
Page generation time: 0.3411
