42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> how to load c channel profile into a stair support (stringer)
Mon, Oct 21, 2013 at 3:44:44 PM | how to load c channel profile into a stair support (stringer)
ziemo1
2014, trying to make a c channel support for stairs but the profile is not aval. in the properties menu??
how do i load this into the project?? like in this tutorial...
http://designreform.net/learning/2012/05/14/revit-2013-component-based-stairs
Mon, Oct 21, 2013 at 3:52:04 PM | how to load c channel profile into a stair support (stringer)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In your project go to insert>load family>find the profile you want for your stringer and load it into the project.
Mon, Oct 21, 2013 at 4:07:02 PM | how to load c channel profile into a stair support (stringer)
NOTE:  That profile's usage has to be set to stair support in the family.
Wed, Oct 23, 2013 at 2:58:24 PM | how to load c channel profile into a stair support (stringer)
ziemo1
tried to load the profile.. it just doesn't load or work.
even when i copy the profile and make it stair based????
Wed, Oct 23, 2013 at 3:23:10 PM | how to load c channel profile into a stair support (stringer)
You have to use stair by component.
Wed, Oct 23, 2013 at 3:45:38 PM | how to load c channel profile into a stair support (stringer)
ziemo1
still won't work no way
Wed, Oct 23, 2013 at 3:59:20 PM | how to load c channel profile into a stair support (stringer)
What Revit, what update?  Always start with that in your posts.
Wed, Oct 23, 2013 at 4:08:02 PM | how to load c channel profile into a stair support (stringer)
ziemo1
same as before...2014 revit
in the video (http://designreform.net/learning/2012/05/14/revit-2013-component-based-stairs)it works so good???
how do i get this profile in myb template?? maybe it would work from there??
Thu, Oct 24, 2013 at 7:00:35 AM | how to load c channel profile into a stair support (stringer)
2014 has an update - install it.
Thu, Oct 24, 2013 at 8:11:44 AM | how to load c channel profile into a stair support (stringer)
I just looked at the profile used in a new project using a standard template.  The profile is assigned "generic" and not assigned to stairs.  Try a new project using the commercial template.  You will find the channel profile there.
Fri, Oct 25, 2013 at 8:36:45 AM | how to load c channel profile into a stair support (stringer)
#11
ziemo1
yes finally this works thank you
C-channel Stair Stringers
Wed, Apr 20, 2016 at 10:22:32 AM
Stringer in Stair by Run: Problem with offset
Tue, May 6, 2014 at 7:44:19 PM
Stringer as rail profile problem
Tue, Mar 25, 2014 at 8:27:15 AM
C-Channel Profile sweep issues?
Fri, Apr 29, 2011 at 11:47:25 AM
Steel Stairs with Channel Stringers
Wed, Jun 7, 2006 at 11:33:31 AM
Page generation time: 1.7081
