39 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Adding formula to change identity data and heights of components
Mon, Oct 21, 2013 at 4:50:39 AM | Adding formula to change identity data and heights of components
DanP87
Hi All,
Could you please advise a solution for changing the identity data information and heights by possibly adding formulas.
We create wall partitioning within nested families and we add identity data such as ‘model no’ etc for scheduling purposes in Revit 2013.
We would now like to add parameters to increase the width or height of some of the components.  We have set heights for example 25mm , 40mm  and 50mm. If we change the parameter to a set height, is it possible to add a formula to automatically change the identity data as well as the height of a component?
So for example:
If the composent height is;
25mm - then the identity data ‘model no.’ is to be 0271
40mm – then the identity data ‘model no.’ is to be 0272
50mm – then the identity data ‘model no.’ is to be 0275
If this can be done, it will save us time from creating additional panels.  Your advise on this issue will be much appreciated.
Mon, Oct 21, 2013 at 5:02:10 AM | Adding formula to change identity data and heights of components
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
See illustration.
Planta1 Revit Online Consulting | info@planta1.com
room system families: adding identity data
Tue, Aug 5, 2008 at 5:24:15 PM
Identity Data
Thu, Oct 6, 2005 at 10:21:04 PM
Editing existing Identity Data in a Family
Tue, Sep 22, 2009 at 12:34:43 PM
Change Identity Data on Manufacturer Family
Thu, Mar 14, 2013 at 2:33:15 PM
Delete Identity Data
Mon, Sep 30, 2019 at 7:05:27 PM
Page generation time: 1.0961
