57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Adding Attributes to Revit Families/Components
Sat, Oct 19, 2013 at 7:15:40 PM | Adding Attributes to Revit Families/Components
MattyHeis
Is it possible to add attributes to families/components in Revit. I am consulting with a firm who is considering making the change to Revit that mainly deals in equipment layouts for big box stores, manufacturing, restaurants, supermarkets, etc. Sometimes the same piece of equipment is needed in two different departments and need to be reflected as such in the purchasing/equipment schedule provided to the client. For example, a 48"w x 18"d x 60"h shelving rack may vbe in both the seafood and produce area of a supermarket and needs to be shown as such on a purchasing/equipment schedule. I know that AutoCAD has these capabilities using blocks,  attributes and extractions. Every time the block is loaded into the project a dialogue box appears allowing the user to insert the necessary information. Does Revit have any way of doing this? I have looked into shared properties as a solution, but I am very new to that are of Revit and it seems a bit cumbersome. PLEASE HELP!!!
Thanks!
Mon, Oct 21, 2013 at 7:53:20 AM | Adding Attributes to Revit Families/Components
3.5 Stars: 395 Votes
Shared parameters are one of the true powers of Revit.  They can be type based (all instances the same) or instance based, they can be scheduled, they can be tagged and they can just be data or they can control the famill parametrically.  (ie - length).
In Revit, you can also apply schedule defined parameters that are created at the project level and are shown in the schedule.
I suggest you get a good Revit book then download Revit to try some of this out.
Mon, Oct 21, 2013 at 9:31:12 AM | Adding Attributes to Revit Families/Components
MattyHeis
Thanks! I have Revit 2012-2014,and currently searching for a good Revit text to study. Are there any good books you recommend?
Thanks again!
Mon, Oct 21, 2013 at 9:39:36 AM | Adding Attributes to Revit Families/Components
All of these seem to be pretty good.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Dstripbooks&field-keywords=revit%202014&sprefix=revit%2Cstripbooks&rh=i%3Astripbooks%2Ck%3Arevit%202014
Attributes and REVIT
Mon, Oct 24, 2005 at 6:13:59 PM
room system families: adding identity data
Tue, Aug 5, 2008 at 5:24:14 PM
I want to create like attributes within my families
Thu, Jan 28, 2010 at 7:03:23 AM
Electrical Fixtures: Component families?
Tue, Sep 11, 2007 at 8:38:42 AM
deleting old components
Sat, Apr 11, 2009 at 12:28:12 PM
Page generation time: 2.4102
