48 Users Online (46 Members):
Forums >> Revit Structure >> Technical Support >> Concrete beam Lateral Justification error
I changed the OTB concrete beam (structural framing member) width and depth parameters to be instance and not type parameters. I've noticed now that the Lateral Justification no longer works correctly. When the beam is set to Side 1 or Side 2, it acts like it's set to center and the beam width will adjust based off its current center line instead of the specified side. Is there a check box or something that I am missing that will fix this? I've included a couple pictures showing how the beam changes when set to instance vs. type. Thanks for the help
curved concrete beam |
Fri, Oct 17, 2008 at 6:10:21 PM
What does this error means please? |
Thu, May 3, 2007 at 2:53:30 AM
Beam system justification |
Fri, Jan 27, 2012 at 3:47:56 PM
Concrete Beam and Slab |
Mon, Jun 3, 2013 at 2:47:31 PM
PFC rotating |
Mon, Aug 18, 2008 at 1:48:58 PM
Members: | 2022335 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
