70 Users Online (69 Members):
Forums >> Revit Building >> Technical Support >> Trouble with join geometry with Roof fascia
24 Posts No Rating |
I've used the roof fascia tool to create the rake and I created a component for the return. When I try to join the two together I can't get them to blend together to appear as one smooth transition. What am I doing wrong?
You made an in-place component for the return? What is the weird angled part? Are they the same material and category?
Also jsut a note, it doesn't appear your ridge line meets correctly. Did you do this a 2 separate roofs for some reason?
Edited on: Fri, Oct 18, 2013 at 9:37:53 AM
Thanks Tea, not sure why I did two seperate roofs either. I've adjusted based on your suggestions. I actually created a family for the return, its a generic family, do think that could be the reason they are not joining? My goal is to create the roof trim in a quick, repeatable fashion using the roof fascia tool and the family I created.
Roof Join / Entension Trouble |
Thu, Feb 11, 2016 at 9:52:09 AM
Fascia on Sloped Glazing |
Tue, Aug 23, 2005 at 11:58:53 AM
RAC09 - Roof Fascia Corner Miter on Square Cut |
Wed, May 27, 2009 at 6:57:00 PM
Sloped Roof Fascia |
Wed, May 29, 2013 at 1:23:20 PM
Cannot join two rooflines - one new and one existing. |
Tue, Oct 20, 2015 at 2:07:27 PM
Members: | 2042200 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
