53 Users Online (52 Members):
Forums >> Revit Building >> Technical Support >> Custom Material Library Problem
![crwinchester Avatar](user_avatar/187252.jpg)
![4 Stars: 5 Votes](/images/stars_4.gif) |
I created some custom materials with custom assests built with jpeg images etc. I saved this library out to my project folder. Now, Revit cannot use these materials in the project, says that the library is empty, and when tring to open into the project it says its in use by another library. Huh? Shouldn't saving out your library make so that it can be used lets say, more than once? Now the whole library is unusable. Please help me figure what Revit wants here? How can I create a custom library to be used for more than one project? Thanks.
Had to delete in start over. No solution.
No one has a solution to this? It seems like this is fairly important component to not be working.
Material Library with custom parameters. |
Fri, May 6, 2016 at 3:36:29 PM
Question about shared custom material library |
Wed, May 18, 2016 at 6:44:31 AM
User material Library upgrades |
Thu, Mar 1, 2007 at 3:05:03 PM
How do you add an imported material to Revit's material library ? |
Mon, Aug 16, 2010 at 8:06:17 AM
Material library |
Fri, Mar 3, 2006 at 9:11:37 AM
Members: | 2022271 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
