56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Wall/Floor Assemblies
Thu, Oct 17, 2013 at 3:47:21 AM | Wall/Floor Assemblies
Rachit
3 Stars: 2 Votes
Hi Guys,
What standard procedure should be used in Revit.
1. Should we model the complete assemble of walls/floors including the finishes eg plaster/AAC block/plaster.
or
2. Should we model the structural wall/floor seperately and have the finishes as a seperate model.
The second method allows you to model more accurately but it defeats the purpose of revit.
I want to understand the pro's and con's for both the systems.
Thanks in advance.
Thu, Oct 17, 2013 at 7:45:04 AM | Wall/Floor Assemblies
We model all of our walls accurately for material but not always color.  The only exception is tiled walls area.  We will often model that as a thin wall and join it to the wall.  We basically do the same for floors.  We don't model carpet and we will model thin tiled floor areas but the floor is otherwise complete.
Tue, Oct 22, 2013 at 2:03:34 AM | Wall/Floor Assemblies
Rachit
3 Stars: 2 Votes
WWHub:
So essentially what you are saying is that we should model the structure seperately and the finish seperately whether it is tiles or wooden panelling etc.
Tue, Oct 22, 2013 at 7:19:54 AM | Wall/Floor Assemblies
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What WWHub is saying is if you have a 3 5/8" metal stud w/ gypsum board on both sides you would create that as one wall.  If you have a  3 5/8" metal stud w/ gypsum board on both sides and one of the sides has a tile wainscot he creates that separately then joins them.
FLOOR ASSEMBLIES
Sat, Feb 26, 2005 at 8:25:19 PM
Tag two same wall assemblies - one with sweep, one without
Fri, Jul 27, 2018 at 12:29:20 PM
Sound Transmission Evaluation of Assemblies
Wed, Jul 18, 2007 at 11:35:32 AM
copying assemblies between projects
Fri, Jun 1, 2012 at 10:39:32 AM
Graphic display options assemblies
Thu, Nov 21, 2024 at 3:35:02 PM
Page generation time: 15.0643
