Forums >> Revit Building >> Technical Support >> Trying to make a non ADA ramp but always have problems with railings, need help!
Tue, Oct 15, 2013 at 8:45:45 PM | Trying to make a non ADA ramp but always have problems with railings, need help!
neonenvy
the error showing up is "Cannot create continous rail geometry", is there anyway to possibly shut off the rails and add them in later separately?
*note - its not a steep ramp but does not follow the 30' ADA standard, this may change in the future, it also has a few curves which I presume may be the culprit
Wed, Oct 16, 2013 at 7:18:20 AM | Trying to make a non ADA ramp but always have problems with railings, need help!
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Yes you can create railing separately after you complete your ramp.
Wed, Oct 16, 2013 at 9:10:43 AM | Trying to make a non ADA ramp but always have problems with railings, need help!
oneworld279
I always run into this problem with Modeling and curves. Sometimes revit just cannot create a sweep when the curve is too small/sharp. Like teafoe said, you can create it later seperately.
In Solidarity
3D ADA Ramp
Thu, May 1, 2008 at 9:45:11 AM
ADA Ramp
Mon, Jun 20, 2005 at 6:21:23 PM
Railing at ramp and stair
Fri, May 29, 2009 at 7:40:59 AM
railings arain...
Tue, Oct 20, 2009 at 2:17:20 PM
Railings floating above the ramp?
Wed, Aug 13, 2008 at 11:02:33 AM
Page generation time: 3.4862
