Forums >> Community >> Newbies >> Nested annotation labelt o report a family parameter?
8 Posts No Rating |
I'm doing a plan showing a variety of sizes of tables, and rather than tag the furniture I'd like to have a label inside the family object instead (object attached, with a nested generic annotation label).
I can get the label to show up, but it seems stuck on showing a single output, an instance parameter type mark, which i have as a text parameter.
It should instead show the type Mark different for each of the different types?
It changes OK within the Family Editor, just not when I have a variety of sizes and obviously Types on my floor plan.
Can anyone suggest where I am going wrong?
36 Posts No Rating |
on "Type Mark" instread of instance parameter change to Type parameter
8 Posts No Rating |
Tried that first time and didn't work so had changed it to By Instance, changed back to being a Type Parameter and unfortunately still doesn't work.
See attached for what i see on my plan.
Does it work for yourself though?
If so must be something else...
seem working ok here
8 Posts No Rating |
Dang, I wasn't reloading it into the project properly.
Do it right and it works....
Thanks for the help
nested annotation families in detail family not showing up? |
Mon, May 10, 2010 at 9:11:21 AM
Issue with annotation nested with generic model family |
Wed, May 25, 2016 at 9:46:11 AM
Nested Annotation Family in a Detail Component |
Fri, Mar 16, 2012 at 8:56:46 AM
Generic Annotation with Family Category based parameter |
Mon, Sep 16, 2013 at 7:18:16 PM
Shared Parameter in nested annotation formulas |
Fri, Dec 16, 2016 at 2:47:07 PM
Members: | 2102338 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
