128 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> flow gpm & fu
Mon, Oct 14, 2013 at 6:57:40 PM | flow gpm & fu
DESIGN4BUILDING
DESIGN4BUILDING Avatar
3.5 Stars: 3 Votes
I read in the revit info that the calc for flow use ipc table E103.3 table. When I tag to show flow & gpm it is spot on with that table. But it is spot on with the flushmeter side for the calc. What about the flush tank side for res. Can it be change Attatch is the chart in pdf
Pendant sprinkler head not hosted
Thu, Jul 28, 2011 at 3:03:35 PM
Piping flow arrows
Thu, Jan 20, 2011 at 5:40:32 PM
Domestic Hot water - No flow
Fri, Dec 11, 2009 at 3:50:06 PM
Reporting Flow In a Pipe Run
Fri, May 8, 2015 at 3:24:05 PM
Piping - direction of water flow
Mon, Nov 15, 2010 at 7:57:20 AM
Page generation time: 0.5614
