Forums >> Revit Building >> Technical Support >> Mirroring
5 Posts No Rating |
So guys. I had to mirror my whole project to keep it from falling of a cliff. Mirroring went fine, but now my section lines are not where they belong in all my views, and they are upside down in others! Whats worse is, I go into fix them and the others flip around. What am I doing wrong here?
You should mirror the model only, then redo all annotations and re-compose your views.
Try to copy that project with a new name, delete all annotations, then open the old file with the new one side by side, using copy and paste to re-place all annotations.
Or you can turn off all annotations, mirror the model, then turn all annotations on, move them to the correct locations.
Edited on: Sun, Oct 13, 2013 at 10:29:04 PM
5 Posts No Rating |
Thanks, I ended up removing all the sections, replacing, and renaming. All the other notes seemed to be functioning normally.
Mirroring House model |
Wed, Oct 27, 2004 at 4:33:15 PM
Mirroring text |
Mon, May 12, 2008 at 6:25:24 PM
BE AWARE .... REVIT problems with mirroring |
Tue, May 22, 2007 at 12:43:55 PM
More Mirroring |
Fri, Mar 23, 2007 at 1:01:52 PM
Opening in Generic Model Standing seam roof |
Mon, Aug 17, 2009 at 9:43:33 AM
Members: | 2099066 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
