20 Users Online (19 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Millwork Family that Can Follow a Path
Thu, Oct 10, 2013 at 7:32:52 AM | Millwork Family that Can Follow a Path
ivanjay205
Hi all.
We are using Revit 2013 and are a foodservice consultant.  The most complicated piece for us to model are millwork cabinetries because it is very often not a linear design.  Their are curves and all types of shapes....
This complicated things when it comes to sections because we have to detail everything in a drafting mode as we use extrusions for the millwork bodies which give us nice renderings and profiles for sections.  But no detail as to what is really going on in that cabinet.
Is there a way to make a detailed cabinet family and when we insert it pick a model line or some other element within the model and my family would "follow" that path.
Kind of like a sweep, but with an entire family?
If so that would be an AMAZING timesavor if we take the time to make the family right.
Thu, Oct 10, 2013 at 8:12:30 AM | Millwork Family that Can Follow a Path
Sorry - no way to do this - you would have to sweep individual elements.
Fri, Oct 11, 2013 at 4:15:05 AM | Millwork Family that Can Follow a Path
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
I'm not sure before i see the shape of your millwork model, but how about using railing? railing can have repeatative panels, and contisuous sweep rail in one family.
or, adaptive component can be used i guess.
want more?
You can get more tips at Enjoy Revit
Tue, Oct 15, 2013 at 8:55:54 AM | Millwork Family that Can Follow a Path
ivanjay205
The attachment is a pdf of some presentation material we created for a client.  You can see the millwork final design here.  We had to model this all individually.  I know the finishes could present a problem but very often we have uniform finishes on cabinets and I would love to be able to have millwork follow a path.
Thanks for all your help all!  I would hope there is a way, but understand there may not be.
Tue, Oct 15, 2013 at 9:07:20 AM | Millwork Family that Can Follow a Path
No attachment
Tue, Oct 15, 2013 at 12:10:49 PM | Millwork Family that Can Follow a Path
ivanjay205
That is what I get for trying on a slow internet connection.  It must have dropped out.
Edited on: Tue, Oct 15, 2013 at 12:13:16 PM
Tue, Oct 15, 2013 at 12:33:28 PM | Millwork Family that Can Follow a Path
We do this kind of work all the time in our hotels but we don't do them as a family.  Sometimes, we may use family elements if there is more than one of something but in most cases, this kind of work is best done, in-place - as casework.  In the project, you can pick 3D paths for sweeps using millwork profiles.
Tue, Oct 15, 2013 at 12:36:06 PM | Millwork Family that Can Follow a Path
ivanjay205
But the millwork profile will not give me enough detail to easily generate a section, correct?  That is what I was looking to achieve but if no way, there is no way...
Tue, Oct 15, 2013 at 12:55:37 PM | Millwork Family that Can Follow a Path
Have you looked at the millwork profiles available?  Look at one of the stock ones I attached.
Thu, Oct 17, 2013 at 12:54:54 AM | Millwork Family that Can Follow a Path
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
why don't you insert detail components to the profile?
you can discribe all kinds of details with detail componets at section views.
watchi this.
http://youtu.be/qbknX7XooaI
want more?
MILLWORK MANUFATURERS? anyone use revit for that?
Mon, Mar 2, 2009 at 6:03:23 PM
millwork families to have hatch in plan view only
Tue, Jan 26, 2016 at 9:54:59 AM
3D path insteads of 2D path
Mon, Mar 28, 2005 at 9:23:38 PM
Vanity millwork with double sink family
Fri, May 4, 2012 at 12:45:45 PM
Creating custom millwork with reveals and counter tops. custom dining seating
Sun, Dec 19, 2010 at 8:42:59 AM
Page generation time: 2.6943
