111 Users Online (110 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Converting !
Mon, Oct 7, 2013 at 1:05:33 PM | Converting !
manb
How can I convert an older version of revit file to a newer one ?
And is that even possible Smile
Thanks !
Mon, Oct 7, 2013 at 1:08:00 PM | Converting !
manb
and i forgot to mention, it's a family file.
Mon, Oct 7, 2013 at 1:12:09 PM | Converting !
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Just open it and save it in the version.  Just remember once you upgrade it you cant open it in an older version anymore.
Mon, Oct 7, 2013 at 1:13:38 PM | Converting !
manb
yup, that's the problem. my version is upgraded, so i can't even open it Smile
Mon, Oct 7, 2013 at 1:17:54 PM | Converting !
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
That doesn't make sense. You said you cant convert an older version of a revit family to a new one...if the family is saved in for example 2012 you can open it in 2013 and 2014 but not in 2011, 2010 2009 etc.
What version are you using and what version is the family saved in?
Edited on: Mon, Oct 7, 2013 at 1:18:32 PM
Mon, Oct 7, 2013 at 1:23:52 PM | Converting !
manb
i downloaded the family from here(RevitCity) so i don't know what version it is. i am using Revit 2013, but when i open the file it says that it's saved in older version so it can't be open.
but now i see it is for 3Ds http://www.revitcity.com/downloads.php?action=view&object_id=14552 my mistake :/
Mon, Oct 7, 2013 at 1:25:49 PM | Converting !
manb
is there some way i can use that exact family in revit?
Edited on: Mon, Oct 7, 2013 at 1:29:50 PM
Mon, Oct 7, 2013 at 1:30:38 PM | Converting !
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
For some complicated shapes such as furniture that Revit isn't really built for making we use models made in programs such as sketchup.
Mon, Oct 7, 2013 at 1:35:47 PM | Converting !
manb
okey thank you.
converting masses?
Wed, Nov 22, 2006 at 2:48:09 PM
Any known problems converting projects to 2009 form 2008?
Thu, Aug 21, 2008 at 5:49:14 PM
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:30 AM
converting revit sheet to image
Sat, Mar 23, 2019 at 10:44:31 AM
converting a revit file into PDF
Fri, Apr 7, 2006 at 2:18:17 PM
Page generation time: 0.5581
