Forums >> Revit Building >> Technical Support >> How to model Sweep/ Blend/ Revolve in family
17 Posts No Rating |
Hi
There are functions like sweep, blend, revolve, extrusion in project mode.
However I couldn't find these functions in family mode.
How can I model some special forms in family mode?
Thank you very much
What program are you running? See below.
Hi
Thank you for your reply.
I use Revit architecture 2013.
Please see the attached pictures, I dont have sweep/blend...., only "create form" fuction.
Where can I find those fuctions
Thank you very much
Your in a conceptual mass family, that is completely different.
You are using a conceptual mass template. That uses the push/pull that you see. Use a different template if you want traditional tools.
Ahh, now I see.
Thank you very much :-)
Blending + Revolve + Sweep. |
Tue, Jan 8, 2008 at 8:48:41 PM
Blend sweep problem |
Tue, Feb 28, 2012 at 1:51:36 PM
Create form tool for components other than mass - Revit Architecture 2012 |
Mon, Oct 20, 2014 at 4:15:59 PM
using revolve tool to shape top of walls 'Revit 2012' |
Wed, Feb 20, 2013 at 2:47:56 PM
Sweep and Sweep/Blend Component |
Mon, Apr 23, 2012 at 12:36:53 PM
Members: | 2115383 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
